Found your Support case. Are you using v1? I just tried against your org and the call worked.
Also works against my org ID. I might have had v0 in call when I tested earlier. Or, something else was broke and magically got resolved within the past few minutes.
I also see the Support NSE just emailed you the same thing 😉
Ryan / Meraki SE If you found this post helpful, please give it
Kudos. If my answer solved your problem click
Accept as Solution so others can benefit from it.
