device ssh?
extopo41
device ssh?
We are doing a security audit and the vendor is asking if its possible to ssh to meraki devices ie firewall/switch/ap's.  The use Tenable Nessus scanner to ssh and run scans against the device.
Mloraditch
Meraki Managed devices do not have ssh enabled.
Cloud Monitored Catalyst Switches and WLCs can have SSH but that is not determined by the dashboard but by the local config.
IvanJukic
Meraki Employee All-Star
Hi @extopo41 ,
The Local Status Page(LSP) is used to connect to Meraki devices. It is accessible securely via the local web browser on a host computer with credentials. The LSP uses secure connection between the host computer and the Meraki device to protect these sensitive settings.
For further details refer to the below section; Controlling Remote Access to the Local Status Page of the guide below
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
Mloraditch
extopo41
Thanks for the replies.
