Wireless Map and floor plans
Floor plan is not saving after configuring? Anyone else having issue or am I missing something?
Thanks!
Accepted Solutions
Re: Wireless Map and floor plans
Appears this has been corrected. I opened up the Map and floor plans tab and found all my floor plans saved. I created another one and verified it was saved immediately. Hope it is working for others as well.
Thank you!
6 REPLIES 6
Yes, I had this issue a few weeks ago. Lasted a few days. Then it finally resolved by “magic”.
Thank you, hope to get a little "magic" myself!
What format is the floor plan in and what size is it?
Sometimes when I have had an issue I save it in another format like PNG.  I notice that smaller floor plans (say under 2MB to 3MB) "perform" much better as well.
Here are the properties.Here are the properties.
Going to try from a Mac next?
Same problem here
Thank you!
