We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
Is there a way to see public IP for clients connected via VPN. Currently all clients show under- Network wide- Monitor- Clients. I don;t see an option to add the column. The ipv4 is lan address.
Solved! Go to solution.
It's not as easy as a monitoring column, but check your event log for "VPN client connected". It'll show you something like:
local_ip: 172.16.34.11, user_id: bob, remote_ip: 1.2.3.4
