Has anybody found a way to intergrate Meraki with Twilio? Trying to get notifications when equipment is down sent to Twilio and then onto a personal mobile phone.I did find this pervious topic from nearly 4 years ago but wanted to see if anything has changed, https://community.meraki.com/t5/Dashboard-Administration/Meraki-text-message-alerts/m-p/13502
Thank you in advance
Solved! Go to solution.
Maybe it will help you.
Network Alerts and Notifications - Cisco Meraki Documentation
Integrate the Cisco Meraki API with the Twilio API - Pipedream
Thank you @alemabrahao I think Pipedream is what I need
I have not used it myself, but I have heard of many people using PagerDuty.
https://www.pagerduty.com/integrations/cisco-meraki-alerts-dashboard/
It uses webhooks from Meraki to send alerts to PagerDuty, and then PagerDuty alerts you.
Did I mention they have a free plan for just basic alerting?
Thanks Philip, will take a look at this as well
