The schedule upgrades tab current firmware column should show a firmware version matching the version on the device status pages.
The overview tab only shows every current version available it does not mean those versions have been applied to your networks.
If you are saying the schedule tab and the device status show different versions AND it's not an instance where the device doesn't support the latest version, then there is some sort of GUI bug and you should open a support ticket.
