Unbinding Networks from templates and retaining configuration
Fastburner
Hi Community,
I have a project I’m working on to unbind my networks from templates. I am using the retain confirmation flag and it seems to work majority of the time, however sometimes the objects in the firewall change from the VLAN object to the CIDR… obviously for management this is a bit of a nuisance.
anyone had this same issue?
RWelch
After unbinding, the network loses access to the template's VLAN object mapping, so the Dashboard replaces the object with the actual subnet.
This is expected behavior and can make management more challenging, as object-based rules are easier to maintain at scale.
DarrenOC
Expected behaviour. Best feature of templates is the Unbind and keep config buttons.
out of interest why are you unbinding?
I had had to do this a lot.  I always have to restore the IP configuration on the VLANs on MX.
