Apr 2 2024
3:34 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Apr 2 2024
3:34 AM
Summary Report Timing out
I have dozens of contracts built and all work okay when exporting the Summary Report, however I have 2 contracts that will not export at all. On the ones that fail i get the error "An error occurred while attempting to export data" after about 1 min.
I have changed the report to cut down the data same thing, the email report works but the csv export does not work, it's the same setup for all contracts i have which they all work fine just 2 are timing out.
If i select a Networks "Entire Org" it fails but separate sites are okay, this is not one of my largest networks.
Any suggestions on how to get the data they are on the same domain as the working ones.
1 Reply 1
Apr 2 2024
4:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Apr 2 2024
4:30 AM
I suggest you open a support case.
