licensing
Abechara
licensing
Any way to split two organizations with spliting licensing and configurations , please note that my license is cotermination
thank you in advance
5 Replies 5
Yes, there is, as long as it is part of the same organization, it would be interesting to contact Meraki support.
https://documentation.meraki.com/General_Administration/Licensing/How_to_Request_a_License_Transfer
Abechara
for the moment i am the owner of the two organizations but later on i will separate them
Who Can Request a License Transfer?
Only organization administrators with full read/write permissions on both source and destination organizations will be able to request a license transfer.
The full org administrator requesting the transfer must have the same email address on the source and destination organizations.
SAML administrators (assigned a role that grants full organization privileges) may request license transfers, as long as there is a local administrator that meets the above requirements that can be utilized as a "placeholder".
Meraki Support will NOT proceed with a license transfer if it is requested by:
  • A read-only organization administrator
  • A network administrator
  • An administrator who only has sufficient permissions for one of the two involved organizations
  • An administrator who manages the source and destination organizations under different accounts (regardless of permissions)
  • A SAML administrator (regardless of permissions) if there is no local administrator to act as a placeholder
Required Information
Information required to proceed with the license transfer:
  • The source license key that will be utilized for the transfer (the twelve-digit code in the format "Z2##-####-####")
  • The device type(s) and count to be moved to the destination organization
    • It is possible to move only a selection of licenses from a full license key
  • Name and link for the destination organization
  • The requestor's 4-digit administrator support passcode for the source and destination organization
Ryan_Miles
Meraki Employee All-Star
Support can help with an Org split (which includes licensing). This is a coordinated effort and special process of keeping configs intact while splitting the Org.
The other option is create a new Org, rebuild configs there, move devices, then move your licenses. You can do all those actions including the license move without Supports involvement. https://documentation.meraki.com/General_Administration/Licensing/How_to_do_a_License_Transfer_in_Co...
Warren
Also note on orgs that use saml logins - you need to leave yourself as a regular organization admin with an alias email address in order to get notifications about licenses.  Meraki just turned off our organization that is licensed till 2027 because a device was added to the dashboard but the purchased license was applied.  The only notice that is sent is to the non saml org admins.
