Send Meraki Logs to a Backup Server
MyName1
Hello all,
i will send my meraki logs to a backup server.
Unfortunately, I cannot find the appropriate setting (setup) in my dashboard.
My instructions say that I should select (per network): Security & SD WAN => Monitoring => Logging. But I get stuck after “Security & SD WAN” because there is no Logging option under the Monitoring menu item.
Where can I enter an external server that stores my monitoring/log files?
Thanks in advance.
JamesT91
MyName1
big thanks for your reply
i will read the fine 😉 manual
JamesT91
Thank our AI overlords 😉🤖
