Search Dashboard Function
Shadius
What's going on with searching now?
Before, you could type in the search bar to search for anything in the Dashboard. That does not seem to be working anymore.
For example, if I search for "network", nothing shows up, or "geofencing", etc.
Anybody else having this issue?
There seems to be some kind of time-based bug at the moment.
If you load the page, wait (say) 10s, and then do your search it seems to work.
If you load the page and immediately search, it doesn't seem to work some of the time.  For me, it works sometimes and not others.  If I wait and then do the search it seems to work always.
I was doing a screen sharing sessing with a product manager at Meraki which using the search function and they saw it not working some of the time for me.  So you can rest assured someone is looking at this.
2 REPLIES 2
Shadius
Thank you, @PhilipDAth
I thought it was odd. Glad I'm not the only one who's experienced this.
