SSO Single Signon SLO Logout URL
RestaurantGuy
Whenever my login times out or I log out when using SSO I am getting an error message AADSTS750054 SAMLRequest or SAMLResponse must be present.  Does anyone have any experience with this?  It seems that the SLO Logout URL is what is passed to the browser and it matches the address bar, but my attempts and changing it are not working either.
Any feedback or examples would be greatly appreciated.
PDubs5150
Microsoft asked me to change the SLO logout URL (Meraki Dashboard>Organization>Settings>Authentication) to the following:
https://login.microsoftonline.com/common/wsfederation?wa=wsignout1.0
That resolved the sign out error for us.
As an aside, we access the Meraki dashboard via an Incognito window, so there are no other unintended SSO logouts when using the SLO Logout URL.
I don't know the answer.
What I can tell you is that I never configure the SSO Logout URL.  I find it annoying - because if you sign out of one thing, like the Meraki Dashboard, it signs you out of the Idp so you can not SSO into anything else.
PDubs5150
We have the same problem. Tickets open with Meraki and Microsoft but no resolution yet. Will post a resolution if we find one.
PDubs5150
RestaurantGuy
Thanks a bunch for following up with the URL, that worked great!
