- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Restricting site to site vpn access between networks
I have about 15 networks that are under one dashboard. I have site to site vpn enabled for 2 networks that works just fine. Today I need to connect 2 other networks that do not need to communicate with the first 2. How do I do that? It seems they can all communicate right now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You need to use the vpn firewall to create fw rules.
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
Another option would be to use a group policy that is using stateless fw rules. And apply that to the vlans that are part of the vpn.https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can create an L3 rule on the site-to-site VPN page.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It shows that its for non meraki peers, but these are all meraki peers. Still use that rule section?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I use It for SD-WAN and It works well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
"These firewall rules will apply to all MX networks in the organization that participate in site-to-site VPN (both AutoVPN and Non-Meraki)."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Overview
Administrators have the ability to add firewall rules to restrict the traffic flow through the VPN tunnel for a Cisco Meraki MX Security Appliance. Similar to other Meraki firewall options, this firewall is stateful and will only block traffic if it does not match an existing flow.
Creating Firewall Rules
To create a firewall rule, follow the steps below.
Navigate to Security & SD-WAN > Configure > Site-to-site VPN.
Select Add a rule in the Site-to-site outbound firewall under the Organization-wide settings section of the page.
Fill in the desired parameters for the rule
Select Save changes.
Considerations for VPN Firewall Rules
When configuring VPN Firewall rules, it is important to remember that traffic should be stopped as close to the originating client device as possible. This cuts down on traffic over the VPN tunnel and will result in the best network performance. Because of this, site-to-site firewall rules are applied only to outgoing traffic. As such, the MX cannot block VPN traffic initiated by non-Meraki peers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What should the rule look like. Source and Destination?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Depends on your needs.. but For example:
Allow >
source: location1 and location2 subnet destination: location1 and location2 subnet
Allow >
source: location3 and location4 subnet destination: location3 and location4 subnet
Deny > any any
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
