Regulatory domain mismatch
Hi all,
beginning from this morning, we're seeing a "Regulatory domain mismatch" warning on every network where a MX65W is present (and only a MX65W, no MR access points), although all SSIDs are disabled.
As there are no "Radio settings" to be edited (as stated in the documentation), I don't get the point how to fix this new behavior of the dashboard.
Ideas anyone?
Accepted Solutions
Re: Regulatory domain mismatch
You've already found the best documentation page, although it doesn't specifically address the MX65W (which doesn't show a dedicated 'Radio Settings' page).
You can find the Country/Region for the MX65W by enabling at least one SSID on the MX65W (Security appliance > Wireless settings) and then scroll to the bottom of the page.  If there's a conflict, you should see the warning and have the ability to request the change (based on the rules outlined in the documentation page you linked).
I suspect that once you complete the change, you will be able to disable the SSID again.
This might be a situation best left to a Case with Meraki support though.
3 REPLIES 3
Same issue here, with our MX64.
will Open a case...
Not sure why this is the accepted solution, as it doesn't solve the issue!
It was an error in the config of MW devices that Merkai solved, this method didn't.
