Question about Tags
NJNetworkGuy100
Question about Tags
Is there a place where I can delete old, unused Tags in the Dashboard?
I think the first sentence from this page is out of date:
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Organization_Menu...
5 Replies 5
Ryan_Miles
Meraki Employee All-Star
Tags for what? Networks, devices, clients? You should be able to edit (add/delete) any tags on whatever page you're on.
NJNetworkGuy100
For my purposes right now, Network tags.
But, according to that link above, there should be this:  Organization > Configure > Manage Tags
But I don't see that in my Dashboard.  And I don't see how I can delete a network Tag that is no longer used.
TWishork
Did you ever figure this out?
NJNetworkGuy100
Never did...but I noticed that if a network tag isn't being by any networks, it doesn't show up in the Tags tab in the Org Overview page.  So, that is helpful.
csac_it
I had similar problem in the 'SSID availability', there were several old tags for access points that no longer existed.
Long story short, there were a few SSIDs that we had originally set to only be available on a few access points, which we later changed to 'enabled on all access points', but DID NOT remove the tags from the 'enabled on some access points' before making the change. The old tags were still listed if we looked back into the 'enabled on some access points'. I deleted the tags from there, then switched back to 'enabled on all access points'. The dead tags disappeared.
