Hi everyone, we are having problems to login with 2FA code validation, the login is not recognizing the codes and we are unable to login. Is anyone else experiencing this issue?
I was able to login fine just now without any hiccups.
I've not had any issues, what shard are you using? i.e. one of my Orgs uses n70.meraki.com
@Angelo_Cabrera what method of MFA are you using? SMS or OTP?
