Hello!
I have a customer who is trying to perform a packet capture on a switchport. However, when they click the stop button or wait for the specified duration, they receive the following error message: "Failed to connect to server." Has anyone experienced this issue before, or could it be due to some block on the client machine?
The customer has attempted to resolve the problem by using different browsers, but without success.
On my end, I am able to successfully download the packet capture using the same filters and settings.
Thanks,
Oscar
Solved! Go to Solution.
I suggest you to open support case. It's probably a dashboard issue.
Since it works for you and not them I suspect something in their environment. Maybe software firewall or anti-virus interfering?
We have tested various computers and browsers and it appears that there is an issue specifically with the Read-only account when using SAML. However, when we attempted the same operation with the admin account, they were able to initiate and download the packet capture successfully. We have a started a case for it.
I have had that before. Typically I do nothing and come back to it later and it is working.
