PCI-DSS | Security - Impacting System | out-of-band management | in-scope,out-of-scope
Axtion
Just browsing
Hi i'm asking because of the topic PCI-DSS in-scope/out-of-scope for PCI-DSS 3.2.1.
Meraki itself is already certified right? But what happens with the admin-workstations connecting to the Meraki Dashboard? I think there are in-scope because there are Security - Impacting System arent they?
Do they need to be audited as-well?
Thanks in advance & Best Regards!
2 Replies 2
Adam
Lots of useful info here https://documentation.meraki.com/MR/Other_Topics/PCI_Compliance_with_Meraki
I don't believe Meraki gets certified as much as it is making sure your configuration is PCI compliant.  PCI doesn't operate like FIPS.
Axtion
Just browsing
Hi, i have already read those documents. Meraki is already PCI 3.2 audited/certified/compliant as written in your document. You/we do need the Attestation of Compliance if i want to use Meraki (for the Cloud/Dashboard etc) and get my environment PCI-compliant.
So, my question is still open, the document you linking to is nice, but only way to generic.
Thanks in advance
