No MX summary on Security Center
ChrisL2021
Hi there,
    I have setup Meraki SDWAN with MX65W which established the umbrella connector to HK (primary) and Mumbai (backup). I have enabled AMP and IDS/IPS.
However, under Org>monitor>security center...there is no MX events.
Can I know why?
My MX65W software version is:
Current version: MX 17.10.2
In the security  center click on filter. And select clean and unknown
5 Replies 5
Brash
Have you had any detections?
Events won't be populated unless ips has enforced any detections/preventions
ChrisL2021
Hi Brash,
    Under Security &SDWAN>configure>threat protection:
         Intrustion detection and protection:
            Mode: detection
            Resuleset: Balanced
Is it sufficient?
This is because there was no event detected. Wait a little longer and surely if something is detected it will be displayed on the page.
ChrisL2021
Thanks buddy. Yes, the key is to select Malware, clean and unknown!!
