Hi All,
I have a non PoE switch installed and configured and I noticed the new "Switch Overview" is not accurate as its showing PoE ports that are not drawing power and it claims I have 4 of them, which is not possible. I think the UI may be wrong and It also classes the 2 stack ports as PoE ports, which I would have thought is not correct either, however I may be wrong.
Anyone else seeing this issue as you have to opt-in to the Switching Overview from the Organization early access section.
Switch model = MS225-48
