MultiFactor Authentication on Organization
FlorianDewilde
Hi everyone,
I enforced MultiFactor Authentication on my Organization.
I want to exclude some users (employees who check the camera feed) from 2FA. Is it something possible ?
Thank you
2 REPLIES 2
BrechtSchamp
Not when you check the box "
Force users to set up and use two-factor authentication".
I think you could build your use case if you were using an external RADIUS server. Because then you could have the rules about who needs 2FA defined there instead of in your Meraki org.
If you have a SAML provider like Office 365/Azure AD you could use that, and use its MFA (which lets you enable it per user).
If you use the built in Meraki option and you use the Google Authenticator its free ... so is it that much of an issue?
