Monitoring Packet Loss across the estate
Ashworth
Hi there,
Was wondering if there was a way to monitor packet loss across numerous sites and get alerts should it go over a certain threshold.
At the moment, the only way I can see packet loss is when you go into the Appliance Status in the SD-WAN and view the Uplink tab.  This however is only for one site.  Not sure if this can be monitored and reported across a whole estate of sites, and if so, how this could be done please.
Many thanks,
1 REPLY 1
BrandonS
Check out this post: https://community.meraki.com/t5/Developers-APIs/API-Demo-Platform-quickly-experience-Meraki-APIs-wit...
If you install WebEx Teams you can get alerts for packet loss (among other things).
If you have some basic coding knowledge or desire to learn you could expand upon this using the API to create a custom solution just how you want it.
