Monitor API Keys status
Sofiane19
Is there a way to be notified when an api key has been revoked ?
I have an app that stopped working properly because of that and I'm trying to find to reliable solution to avoid  such an event from happening.
Also where can I find the logs for those kind of actions on Meraki dashboard.
Thank you
GreenMan
API keys are tied to a user's account, not any one Organization so you won't find it in the Org > Change log.  Find the latest key info under the relevant user profile:   login to Dashboard via the appropriate user account, then click the 'head and shoulders' icon top right.   Then click 'my profile' and search for API access.   It will give you a clue as to the currently valid keys (last four characters)  https://documentation.meraki.com/General_Administration/Other_Topics/Cisco_Meraki_Dashboard_API
Hello @GreenMan, thank you for the answer.
Do revoked keys stay visible in the profile page or do they disappear from it ?
GreenMan
They disappear
