Missing products in Meraki BOM Builder
rhbirkelund
Hey,
Is it just me, or is the Meraki BOM builder on merakipartners.com lacking about half of all Meraki products?
There's no MS390, nor any of the .11ax APs. Even the MR74 is missing.
merakichamp
@rhbirkelund  why are you using BOM builder it is no longer functional use CCW instead
9 Replies 9
merakichamp
Really? Hah, awesome. That's not stated anywhere on merakipartners.com
For some reason I can no longer search for Meraki equipment on CCW. I only get some odd Con SKUs..
Just download latest price list from merakipartners.com and then use BoM import in CCW to upload desired skus to your BoM in CCW.
CCW search box has lost Meraki skus but after submitting skus they appear on quote, deal, estimate...
These Con SKUs are the only items I'm getting.
And this.
merakichamp
@rhbirkelund  for the MS390 you need to get the correct SKUs because i can see from the screenshot you shared you were typing the wrong SKU
find the correct ones below and use them
MS390-24-HW
MS390-24P-HW
MS390-24U-HW
MS390-24UX-HW
MS390-48-HW
MS390-48P-HW
MS390-48U-HW
MS390-48UX-HW
MS390-48UX2-HW
merakichamp
@rhbirkelund  don't mind the Con SKUs you are seeing just go ahead and type the the whole SKUs and click add it will just pop up with the pricing
I'll admit. Everything is probably there. But I still think it is lacking, with regards to Meraki. Unless You know the precise SKU name, it's not possible to find it.
same applies for me, just press enter and you´ll find that the skus appear below, if you´ve set the right sku format. dunno why CCW does it in the search phase but its been like that for a long time now
