We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
1. What is the max reporting period for which one can schedule a custom summary report?.
2. What is the retention period for the generated summary report?.
Solved! Go to solution.
#1 I believe we can create reports that span up to 180 days
#2 Is noted at the bottom of this table https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
Thank you!
