Meraki Cloud Dashboard Very Very Slow
fshequin
Greetings,
I'm experiencing very very slow load times for the meraki cloud dashboard, which is scaring me because this is how the dashboard was behaving when my cable modem had gone down and I had to drive 30 minutes away and sit for 4 hours..... waiting for a "Cable Guy" to show up.
is anyone else having trouble with both the web based iOS App and or the Web based dashboard of Meraki Cloud?
Fred Shequine
BTC Consulting
Frederick G. Shequine
Mloraditch
I'm not having any issues on my various orgs, nor are any of my coworkers. Have you switched your mobile to cellular to see if you have the same issue?
fshequin
Thanks Matt.....I thought it was my end or the cloud...but not my equipment..you confirmed at least it's my end or the cloud...
fshequin
I re-installed the ios app and then re-authenticated and turned off my wifi and though weak cellular at my location, loaded completely...albeit slow...but acceptable. all my equipment looks good....I think it's a cloud only issue related to load on the servers or systems involved in loading all the parts and pieces of the meraki cloud control panel....but it's frustrating as I count on watching my equipment to know when I can sit back or have to move....don't want to move on a Friday.
There have been several other posts like this - I think there must have been a Meraki issue.  People are saying it is resolved now.
