Meraki Click-through
duqa
Hi All,
I am analyzing the Meraki data using the Click-through functionality. Can you confirm that the number of devices (356) is the number of devices connected to SSID1 and not the number of devices authorized to surf on internet? Where I can find report about real user authorized to go online?
5 Replies 5
This is not real time, this is the cumulative time you have filtered.
duqa
sorry but I not understood. I am looking the number of clients authorized using the Click-Throught function. It seems that on the dashboard are showed just the number of devices associated successfully (or with some errors) to SSID but I not found anything about the number of device authorized.
You can see it on Wireless > Monitor > Splash Logins.
duqa
Thanks for your reply but you can see the list of devices in splash logins just if you use external RADIUS for authentication. I am using the intenal Click-through function of Meraki without external RADIUS
So, in this case, you can take a look on Organization > Monitor > Location analytics.
On overview page, you will see the cumulative amount of clients.
