Hello All,
i have migrate MX-100 to MX-250 my question is my internet speed shows on client side 900mb Upload and 900Mb download but when client brows something the browsing is slow it keeps loading I don't what is the problem any advice from your side is this is the problem with Service provider or problem with MX.
even i allowed all subnets to from source any to destination any in firewall rule sometimes web browsing works fast sometimes get back to slow and loading.
looking for your nice comments on this!
Solved! Go to solution.
I wouldn't rely on the speedtests provided by Meraki. These should be taken with a grain of salt. Instead use something client side, like speed.cloudflare.com or speedtest.org
What version are you running?
i run Version 18.105
18 is still fairly new, would not use it as production. Or you can try 18.106 it has some latency fixes
Do you have any content filtering configured?
yes we i have configured content filtring like block some spayware and adware in the part of threat contegories phising botnets, malware sites
when I am testing from My.meraki.com dashboard speed test it shows the speed browser based like this looks the attachment.
The same message is reinforced in our documentation
