We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hi all.
We have a client running MR 29.5.1 on all their AP's.
It was recommended for them to upgrade to MR30.6, but I see that MR 30.7 has been release.
Will it be better for them to jump straight to MR 30.7, or do they need to upgrade to MR30.6 first?
Cheers.
Solved! Go to solution.
You can go straight to version 30.7.
Thanks. I see the list of fixes is way longer in 30.6 than in 30.7, but I assume 30.7 will include the same fixes as 30.6 had?
Yes, it has.
Thanks for the prompt reply.
