Hello
Only one security appliance.
Meraki Go - FAQ - Cisco Meraki
>How many security appliances can I have in my Meraki Go accounts?
Only one Meraki Go Security Appliance is allowed in one account. This is due to the fact as one account should be one location, and the Security Appliance should be the entrance to the internet.
You can manage each GX by using Go accounts created with different email addresses. However, you will need to switch accounts.
Doing so does not consolidate GX management, but it is possible to physically place GXs above and below the network.
However, I don't see the need to deploy GX that way in environments where Go is deployed.
And the Go community is more useful for Meraki GO products.
https://community.meraki.com/t5/Meraki-Go-Community/ct-p/go
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
