Lost password Partners Meraki page
MouradDoumer
Hello, I've lost my password or forget to change it when it was demanded, but I have change entreprise for annoter one, with a new email enterprise. Now I cannot change or retrieve my password, because, I'm not be able to connect to this email address. It is possible to change email address on my new own account directly from partners portal ?
If you have changed companies then you should no longer be using the existing login.  The logins are for "partners".
If your new company is a partner then you should register using your new companies email address.
2 Replies 2
CptnCrnch
I don‘t think there will be any chance from the partners page.
Guess the only option you have is Meraki support.
