Integrate Cisco switch SG220-26P in MX Dashboard
RAubraye
Hi all,
My first question in this community
We have an MX 64 and I read instructions how to integrate a CISCO SWITCH SG220-26P.
API key  - Could monitoring then when making pre-check I am facing error enclosed
IP is correct, Username and Password also.
What can be the issue ?
Thanks in advance for your answer, have a great day.
Kind regards
Rodolphe
I'm not sure what we're talking about, but there is no guide for "integrating" It, SG220, and it should work with any vendor.  If you are talking about monitoring SG220 on the dashboard It's not possible.
Thanks a lot for this quick answer, yes it was about monitoring on the dashboard.
Have a nice day.
R
Cisco Catalyst 9k switches can be monitored.  Not the small business switches.
