I cannot receive the verification code from Meraki when I tried to login Dashboard
Benny2025
Just browsing
I cannot receive the verification code from Meraki when I tried to login Dashboard. I am in Shanghai and my cellphone can receive the verification code before. I didn't change any setting. How can I solve the login problem? thanks.
7 Replies 7
Mloraditch
SMS is not always reliable unfortunately.  If you continue to not be able to login you can open a support case and they can turn it off with another org admins consent. Regardless I suggest switching to use an 2fa App once you are back in.
https://documentation.meraki.com/General_Administration/Other_Topics/Two-Factor_Authentication
Benny2025
Just browsing
hi Mloraditch, thank you for your reply. I can download "Duo mobile", but I can not setup it as it requires the user to login Meraki Dashboard first.  Where can I open a support case to turn it off first?
You can use this form to open a support ticket for when you can not log into the Meraki Dashboard.
https://meraki.cisco.com/meraki-support/open-a-support-case/
Fingers crossed the TXT starts working without having to do anything.  🤞
As soon as you regain access, set up MFA with an authenticator app.
I agree with @Mloraditch - TXT is not a safe MFA method.
Benny2025
Just browsing
Thank you Philip, I will try to set up MFA with an authenticator app.
Benny2025
Just browsing
hi Meraki Team
     I submitted a Meraki Go case and I cannot find it today. They asked my below questions
When did this issue first start occurring?
I replied 8th April.
Are other administrators associated with your account also experiencing similar issues?
I keyin my colleague's email account:ken.wong@target.com
If possible, could you have another administrator attempt to log into the account and remove the two-factor authentication (2FA) requirement temporarily?
I asked my colleague to try but it seems failed. I still need the verification code.
When I try to open another Meraki case, the page is loading all the time.
hoaphung
I have facing issue the same unable receive verification code.
