How to put Z3s into their own subgroup?
Kaz769
Greetings Meraki Community!
I was wondering if there is a way to put a group of Z3s under their own subgroup in dashboard rather than having to list every single one under an admin's authority. There are too many to list and the UI wigs out so instead I'd like to create a subgroup of them and then distribute the subgroup authority to our admins who need it. Is there anyway to do that?
I was thinking Configuration template but then VPN mode isn't available and that's their primary purpose in this use case. Not to mention the z3s have their own static ip configuration which wouldnt work in that way either.
Thank you for your time and input.
1 Reply 1
Not really.
You could consider prefix their network names with something like "z3-".  Then you could just type "z3-" into the search and see them all together as one.
> Configuration template but then VPN mode isn't available...
Devices part of a template can absolutely use AutoVPN.
When you add them to a template their LAN IP addressing would be lost, but you can go straight back in and change it back to what you want.
