How to Restrict Accessibility or Guided Access in Meraki?
Tus
I've got several iPads in classrooms and need a way to shut off/restrict Accessibility or Guided Access in Meraki. I can't see where I can apply a restriction or policy for it. I have students using it to apply a passcode to lock the device to one app. While I can remove the passcode using Meraki its a pain and it takes some time to complete. I'd rather not give my "clients" access to the option.
thanks
9 Replies 9
MikeMandalorian
Are these Ipads enrolled DEP ?
Tus
yes
MikeMandalorian
This falls under a Profile  and creating Restrictions
Those Ipads would need Tags and the Profile be assigned to the Following Tags
I could be wrong, but I don't think Apple allows MDMs to control the accessibilty options.
MikeMandalorian
Passcode can be configured not to change  and accounts ,,  Screen time can prevent a few things also
Our Ipads have a Passcode to unlock and then for Screentime a  Passcode only known by IT
You can also set a PassCode Policy Via Meraki MDM Profile settings
Tus
When you say: "You can also set a PassCode Policy Via Meraki MDM Profile settings " would this apply to the Guided Access Passcode?
MikeMandalorian
Sunny21DC
After pulling my hair and searching everywhere , I solved it by disabling the guided access and enable it.
Sunny21DC
I can tell you what worked for me, what i did was this worked on your iPhone, there are some steps you can take to troubleshoot and potentially fix the issue. Here's a guide to help you:-
1. Ensure Guided Access is Enabled:-
  -Go to Settings on your iPhone.
  -Scroll down and tap on "Accessibility."
  -Under the "General" section, find and tap on "Guided Access."
  -Make sure the switch at the top is turned on.
2. Set Passcode for Guided Access:-
  -In the Guided Access settings, make sure you have set a passcode. If you haven't set one, Guided Access may not     work.
3. Reset Guided Access Settings:-
  -If you have previously configured Guided Access settings, try resetting them:
  -Go to Settings > Accessibility > Guided Access.
  -Tap on "Passcode Settings."
  -Choose "Set Guided Access Passcode."
  -Enter your Apple ID password when prompted.
  -Set a new passcode or re-enter the existing one.
4. Check Accessibility Settings:-
  -Make sure there are no conflicting settings in the Accessibility section that might interfere with Guided Access.             Check other settings like Display & Text Size, Motion, Touch, etc.
5. Toggle Guided Access Off and On:-
  -Turn Guided Access off and then on again:
  -Go to Settings > Accessibility > Guided Access, & Toggle the switch off and on.
6. Reboot Your iPhone/iPads:-
  -Sometimes, a simple reboot can resolve issues. Restart your iPhone and check if Guided Access works afterward.
Follow for more details instruction below.
https://www.youtube.com/watch?v=VqJigpKMIJM&ab_channel=TheGeekPage
