Failed Dashboard Login Notification/Alert Options?
Crocker
Want to make sure I'm not missing something obvious. We have a need to notify/alert upon failed logins to the Dashboard. I know the Dashboard tracks both Successful and Failed logins and we can manually review that information.
Is there any way to send some sort of a notification (be it syslog, e-mail, webhook) for Dashboard login failures/account lockouts/etc?
Ryan_Miles
AFAIK there are no alert options for this. You'd likely need to implement SAML or 2FA and have that external auth system alert.
Ryan
Thanks, just wanted to confirm I wasn't overlooking something obvious!
Crocker
Update!
I bounced this question off of our Meraki rep, and Support as well. Support also said there's no way to get this info; However, our Meraki rep clued us in on what is apparently a well hidden feature. There's an ability for Support (whether they know it or not) to enable configuration of SNMP traps from the dashboard for login attempts.
They can toggle that on and expose some configuration options (which you control) that will allow the Dashboard to send SNMP traps to your collector's public IP.
I'll follow-up once we've gotten everything configured and seen what it can do.
Login Attempts page with new option after support enabled it:
Trap configuration options (v1/v2c also available):
