Export Floor Map (with AP location) to PDF?
EOrtizr
this is something that should be so easy to do, but can't find a way to do it,  If I want to have a copy of the AP placement, how do I get it?
2 Replies 2
Mloraditch
Your only option would be to print to pdf or screenshot and save.
This feature may help: https://developer.cisco.com/meraki/api-v1/get-network-floor-plan/ but I can't confirm as I don't have a way to test.
AlexL1
Hi EOrtizr,
Welcome to Meraki Community 🙂
You can use on Windows "Snipping Tool" --> Take screenshot --> Save it as .jpg, .png
At the moment, the feature to export floor map(s) with the APs locations isn't supported.
We take our customer feedback seriously and would encourage you to submit a feature request.
You can make a feature request by going to the bottom right-hand corner of any dashboard window and send the request through the "Give A Feedback" button.
Any wish that is made, sends an email to our Product Managers and Development Teams. These wishes are taken into consideration and are used to help shape our product roadmaps. The most wished-for items are incorporated into product development.
https://documentation.meraki.com/General_Administration/Other_Topics/Give_your_feedback_(previously_...
Please don't hesitate to reach out with any questions or concerns.
