Early Access - Detailed AP power information
RaphaelL
Hi ,
I enabled this feature earlier but I can't find the new info anywhere ? Am I blind ?
I couldn't find the documentation related to this feature.
5 Replies 5
Indeed, enabled it and nothing there on any pre 6, 6 or 6e APs...
jbright
Nothing for WiFi 7 APs either.
MKutka
It is located in the left hand menu after selecting an Access point where IP, Firmware, etc is all located.
KarstenI
The wording is different to an org without this early-access feature, but only the usual info:
RaphaelL
Exact same result on my APs.
