Discovery of Meraki Devices in SCOM / Support system mib-II
AndyP
Are there any plans to fully support the OID's required to allow devices to be discovered in SCOM?
Currently discovery fails using SNMP and according to other posts, it is because Meraki does not support all OID's in the MIB-II system such as:
.1.3.6.1.2.1.1.1
.1.3.6.1.2.1.1.2
.1.3.6.1.2.1.1.3
.1.3.6.1.2.1.1.4
.1.3.6.1.2.1.1.5
.1.3.6.1.2.1.1.6
.1.3.6.1.2.1.1.7
2 Replies 2
@AndyP it has been previously noted in the community that there are no plans for enhancing the current SNMP functionality as the APIs are the preferred method of managing and monitoring Meraki equipment outside of the dashboard.
I'd make a wish though as you may get lucky.
AndyP
Thanks for the reply.
Yeah, kind of frustrating that given most monitoring solutions communicate via snmp that such support of a basic standard MIB is deliberately not supported in order to force people in to using the Meraki monitoring product.
I just hope that Cisco do not do this with all of their other network devices
