Deleting a Network and reusing equipment.
Matt_C
Hello all,
So, I have have a new branch office just up and running with new Meraki equipment, this means the previous branch office Meraki network equipment can now be re-used. The equipment has been recovered and can go back into our stock.
My questions are:- do I just remove the devices from the old netwok and if so do they go back into our inventory? I'm assumeing that as we have claimed them they will go to "unused" but I am unsure, this is my first time doing this 😀
and after that do I just delete the old network once we have "reclaimed" the equipment? I'm not sure reclaimed is the right wording.
Many thanks for your time and help
Kind regards
Matt
Yes, Devices  you remove from the network are still in your inventory.
If you have a empty network and you dont need it anymore you can remove it.
2 REPLIES 2
Matt_C
Thank you very much for the response. That's great I will now go ahead and do that.
Kind regards
Matt
