Deleting Organization
kaoskuning
Hello Everyone,
I am trying to delete an organization in Meraki. But I cannot do this. After entering my password and accepting a warning, I get the following error message: "Error! Failed with the following error(s): Cannot delete organization: it still has active trials"
Need advice.
thank you,
PH
Shubh3738
You will need to contact the Cisco Meraki Support Team for this error. Alternatively, you can raise a case with Cisco Meraki Support for further assistance.
kaoskuning
Hi, thanks for ur advice, will raise a case to Meraki Support.
tnco
It is output that there is an active trial, but has the Free trial been returned?
https://documentation.meraki.com/Getting_Started_with_Meraki/Getting_Started_Resources/Meraki_Free_T...
