We have an environment that has nearly 4000 Organizations hosted under a single Dashboard and often experience timeout messages while bringing up the interface or using rest call to pull data.
Is there any logical way to break up / segregate these organizations into maybe North / South / East / West Regions or or break them up some way to be able to more quickly get to a subset of the Organization ?
Each organization is not *That* huge but it add's up...
Thanks,
Don
What ! No Cut / Paste 😝
Is / was there something we could have done "Along the way" to split things up?
Part of the problem ( maybe) is having All those *Customers* / Organizations managed through one dashboard 😞
thank you for the reply
The only way I see is to use different logins for each set of customers. Add a new login for all North orgs and a different login to all south customers. It's an extra burden for switching between orgs, but at least it will work.
That sounds like a very reasonable approach initially - I'd have to look into how *Easy* it is / would be to slice and dice the Organizations by User !
Thank you !
Don
You must work for a service provider, of some kind (?) I'd recommend engaging with your Meraki partner account team directly to discuss this - potentially to help drive development of the platform, taking such use cases into account.
