We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I have many networks that are managed under our org, and it would be very helpful if the address field was searchable.
Thanks!
-Drew
Hi ,
That would be nice indeed ! In the mean time you can search it via Organization -> Overview :
As a matter of interest, what happens if you ask the AI assistant in the Meraki Dashboard to find networks in a particular region?
It came back w/ no result.
If you enter your address in the Network notes section under Network-wide > General that AI question should work.
Otherwise you need to ask for the location of a specific device with a configured location.
Or, this question works too.
