- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Dashboard advritical update required - device says up to date
Hi All,
So when i view my Orgs Firmware status it tells me i have a critical update required to be applied, however when i go to the device it says the firmware is up to date. Does anyone know why its presented like this?
For info device is currently running 18.107.5. My options are 18.107.8(latest patch) and 18.208 (stable release candidate)
Appreciate any info on it.
thanks 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do you have any template in your organization.?
Can you show the firmware status?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alemabraho,
this is from the device:
There is a template for this network, the device is listed under the template on the dashboard:
This is a sample for all similar devices:
Got me a bit stumped!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What model is your MX? I'm looking here on my dashboard and the latest stable version available is 18.107.2.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alemabrahao,
They are a mixture of MX-100 and MX84.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok, anyway this version is not stable, so I suggest you leave it at the version recommended by Meraki.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The firmware status for 18.107.x seems broken to me, as if you're running 18.107.2 it will say you're good whereas if you're running anything from .3 - .7 it will say warning/critical because there is a .8 patch available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Jimmy,
yeah, thinking that rolling back to .2 might clear it.
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would go up to .8, not down to .2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When you go to the device, and it says Firmware Up-to-Date, this simply means that the device is running the configured firmware for your network. This is as it should be. If you have configured, e.g. MX18.107.8 and it's running MX18.107.5, then the device would complain with "Not Up-to-Date", and would attempt to upgrade to .8. Once this happens the device would most likely be "Up-to-Date" again.
Now, if you go to Firmware Upgrade on your Org-Wide menu, and the firmware says Critical, this means the the firmware has reached its End-of-Support date, and is no longer supported, meaning that there may be security vulnerabilities or severe defects, that may need to be addressed.
If you are running a firmware that is Critical, it's recommended that you move away from that firmware version, to either a Stable or Beta release.
There's more info about it here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Going sideways, I would upgrade to 18.107.8.
