CSV exports
Timellis
CSV exports
We are using the data provided from the Organization and summary report and would like to schedule this however when this is done via a schedule and mailed there is no option for a csv report and the email you get is of no use.
So can this be enabled to provide a scheduled csv report of this and also it is limited to 50 device / counts could this be increased also?
Can this be done by an API maybe ?
Here are the available options.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Summary_Report_Overvi...
Unfortunately you can only define the frequency, and I believe that via API it will be the same thing.
Timellis
Okay then so we cant do the basic csv report at least we know. Thanks
