Dashboard SSO - AzureAD & External Guest Users
Christian_S
We are running into an issue where some of our guest users (vendors) can't access our tenant via SSO. SSO works flawless for a handful of our vendors that do not use AzureAD and their guest accounts show up as username#EXT#@domain.onmicrosoft.com in the SAML sign in logs. However, the accounts that do have Microsoft accounts and use Meraki at their company, show up as their normal username@domain.com  address and will get the login error of "Found existing non-saml user with email username@domain.com". Even though they are not an admin in my tenant, I assume that error is somehow seeing their email in their tenant.
What can I change in my SAML config in Azure Apps to prevent this from happening? Setting the user up as a non-saml administrator is not an option in this case.
Current configuration:
This is a very common issue.  I tend to fix it by changing the "username" attribute to "user.displayname".
9 Replies 9
Here you can find some possible solutions.
single sign on - How to configuring Azure AD sso to allow guest logins - Stack Overflow
Customize SAML token claims - Microsoft identity platform | Microsoft Learn
I appreciate the quick response. The first link doesn't help as we already have guest users who CAN sign in. The issue is specific to a certain type of user as mentioned above.
I am currently reviewing the second documentation.
Oo! Let me give that a shot and I will report back. Thank you!
This did it!!! We now have our external guest users who have non-saml accounts in other meraki tenants able to sign in!
Thank you!!!
mlefebvre
You can't have a SAML user where their email is the same as an email account being used on the Meraki Dashboard, it is not supported.
Which is why I am asking here on how to overcome that.
Network3
Hi Philip/Meraki Team,
I configured SAML SSO configuration on Meraki dashboard as per provided document after enter Azure AD credentials we are getting Java Scirpte page(html page)
From memory, this happens when the SAML roles are not correctly mapped to Meraki roles.
Go to Organization/Administrators/SAML Login History.  Look for an error there.
