This is the tcpdump on my VM:
root@LogAnalytics:~# tcpdump -i ens3 port 514
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on ens3, link-type EN10MB (Ethernet), snapshot length 262144 bytes
18:27:04.404979 IP my.meraki.net.48496 > LogAnalytics.syslog: SYSLOG local0.info, length: 171
18:27:04.405020 IP my.meraki.net.48496 > LogAnalytics.syslog: SYSLOG local0.info, length: 163
18:27:04.405029 IP my.meraki.net.48496 > LogAnalytics.syslog: SYSLOG local0.info, length: 158
18:27:04.405032 IP my.meraki.net.48496 > LogAnalytics.syslog: SYSLOG local0.info, length: 158
So this seems to work, but in the Microsoft sentinel panel i got nothing but the Heartbeat:
This is my config.
/etc/opt/microsoft/omsagent/<workspace-id>/conf/omsagent.d/meraki.conf
<source>
type tcp
format none
port 22033
bind 0.0.0.0
delimiter "\n"
tag oms.api.meraki
</source>
<match oms.api.meraki>
type out_oms_api
log_level info
num_threads 5
omsadmin_conf_path /etc/opt/microsoft/omsagent/<workspace-id>/conf/omsadmin.conf
cert_path /etc/opt/microsoft/omsagent/<workspace-id>/certs/oms.crt
key_path /etc/opt/microsoft/omsagent/<workspace-id>/certs/oms.key
buffer_chunk_limit 10m
buffer_type file
buffer_path /var/opt/microsoft/omsagent/<workspace-id>/state/out_oms_api_meraki*.buffer
buffer_queue_limit 10
buffer_queue_full_action drop_oldest_chunk
flush_interval 30s
retry_limit 10
retry_wait 30s
max_retry_wait 9m
</match>
/etc/rsyslog.d/10-meraki.conf
if $rawmsg contains "flows" then @@127.0.0.1:22033;meraki& stop
if $rawmsg contains "urls" then @@127.0.0.1:22033;meraki& stop
if $rawmsg contains "ids-alerts" then @@127.0.0.1:22033;meraki& stop
if $rawmsg contains "events" then @@127.0.0.1:22033;meraki& stop
if $rawmsg contains "ip_flow_start" then @@127.0.0.1:22033;meraki& stop
if $rawmsg contains "ip_flow_end" then @@127.0.0.1:22033;meraki& stop
And last but not least the first lines of my /etc/rsyslog.conf
# /etc/rsyslog.conf configuration file for rsyslog
# For more information install rsyslog-doc and see
# /usr/share/doc/rsyslog-doc/html/configuration/index.html
#### MODULES ####
module(load="imuxsock") # provides support for local system logging
module(load="imklog") # provides kernel logging support
#module(load="immark") # provides --MARK-- message capability
# provides UDP syslog reception
module(load="imudp")
input(type="imudp" port="514")
# provides TCP syslog reception
module(load="imtcp")
input(type="imtcp" port="514")
# Meraki custom stufF
$template meraki,"%timestamp% %hostname% %msg%\n"
What am i missing?
I am not getting any entries in the "meraki_CL" table.
Thanks 🙂
