Exhaustive SNMP return list from dashboard (MX-85)
TI_MERAKI
I've seen that snmp request is quite a thing with Meraki and many didn't manage to make it work ..
For me the problem is quite different since a have returns from the dashboard on my MX-85 but it looks like I don't get everything .
When I look at the MERAKI-CLOUD-CONTROLLER MIB I can find many usefull OID definitions but I don't get anything from most of them ...
Here is the exhaustive list of the snmp request that works... and I don't see the point of making a dashboard with such little informations .. Did you manage to get more from the dashboard via SNMP
Test 1.3.6.1.4.1.29671.1.1.1.0: organization name=#
Test 1.3.6.1.4.1.29671.1.1.2.1.1.52.76.89.110.99.98.67.98: network id= #
Test 1.3.6.1.4.1.29671.1.1.2.1.2.52.76.89.110.99.98.67.98: network name= #
Test 1.3.6.1.4.1.29671.1.1.4.1.1.248.158.40.132.215.190: dev mac= #
Test 1.3.6.1.4.1.29671.1.1.4.1.2.248.158.40.132.215.190: dev name= #
Test 1.3.6.1.4.1.29671.1.1.4.1.3.248.158.40.132.215.190: dev status= #
Test 1.3.6.1.4.1.29671.1.1.4.1.4.248.158.40.132.215.190: dev contacted at= #
Test 1.3.6.1.4.1.29671.1.1.4.1.5.248.158.40.132.215.190: dev client count= #
Test 1.3.6.1.4.1.29671.1.1.4.1.7.248.158.40.132.215.190: dev public ip= #
Test 1.3.6.1.4.1.29671.1.1.4.1.8.248.158.40.132.215.190: dev serial= #
Test 1.3.6.1.4.1.29671.1.1.4.1.9.248.158.40.132.215.190: dev product code=#
Test 1.3.6.1.4.1.29671.1.1.4.1.10.248.158.40.132.215.190: dev product description=#
Test 1.3.6.1.4.1.29671.1.1.4.1.11.248.158.40.132.215.190: dev network name=#
Test 1.3.6.1.4.1.29671.1.1.6.1.1.52.76.89.110.99.98.67.98.0: vlan network name 0=#
Test 1.3.6.1.4.1.29671.1.1.6.1.1.52.76.89.110.99.98.67.98.1: vlan network name 1=#
Test 1.3.6.1.4.1.29671.1.1.6.1.1.52.76.89.110.99.98.67.98.5: vlan network name 5=#
Test 1.3.6.1.4.1.29671.1.1.6.1.2.52.76.89.110.99.98.67.98.0: vlan number 0= #
Test 1.3.6.1.4.1.29671.1.1.6.1.2.52.76.89.110.99.98.67.98.1: vlan number 1= #
Test 1.3.6.1.4.1.29671.1.1.6.1.2.52.76.89.110.99.98.67.98.5: vlan number 5= #
Test 1.3.6.1.4.1.29671.1.1.6.1.3.52.76.89.110.99.98.67.98.0: vlan name 0=#
Test 1.3.6.1.4.1.29671.1.1.6.1.3.52.76.89.110.99.98.67.98.1: vlan name 1=#
Test 1.3.6.1.4.1.29671.1.1.6.1.3.52.76.89.110.99.98.67.98.5: vlan name 5#
Thank you,
GreenMan
Meraki Alumni (Retired)
In terms of tools to query data from the Dashboard, I would say that the REST API is a much bigger thing than SNMP.   I doubt any further functionality will be added to SNMP in the future, whereas the power of the API solution continues to grow at great pace:  https://developer.cisco.com/meraki/
Try this rather neat documentation / basic API query page, for a flavour:  https://developer.cisco.com/meraki/api-v1/#!introduction/whats-new-in-v1
Just look for the info you're after in the search window, top left
GreenMan
TI_MERAKI
Ok thank you so much, I'll have a look.
Could you confirm that it'spossible to monitor the responses via PRTG ?
Regards
GreenMan
A fairly quick look lead me to this...
https://kb.paessler.com/en/topic/86352-monitoring-via-api
