Cloud Monitoring for Catalyst 9200 routing configuration
JAEYOONKIM
I'm trying to put a 9200 switch into the meraki dashboard.
I don't know my cloud ip address in the routing part
I don't know even if I look at the firewall info on the right side of the profile.
Does anyone know?
I'd appreciate your help.
Tony-Sydney-AU
Meraki Employee All-Star
Hello Jaeyoonkim,
Thanks for posting your questions here in the Meraki Community Forum as well.
That catalyst configuration you're referring to will be added by Catalyst onboarding tool. You don't need to add manually to your netconf.
Check out this (non-official) article about onboarding Catalysts.
- Catalyst on Meraki: Getting Started
I also replied to your support case and we can discuss your questions over there if you prefer.
Hope this helps other people in this community as well.
Cheers!
JAEYOONKIM
Thank you very much
Until now, I was checking because I thought I was putting it in manually.
I found out that equipment registration also requires a license.
I wish you all the best for your future.
Thank you
Tony-Sydney-AU
Hi Jaeyoonkim,
Thanks for the positive feedback and this update. It was a pleasure working with you on the support ticket. I love when there's another engineer on the customer side that never gives up like you did. Congratulations and may you have success and all the best for you in your professional career.
