Client VPN when my MX100 has an private IP
Schiller
Good morning/afternoon all,
How do I establish a client VPN into my MX100 if my site location has a public IP address while my MX WAN port has a private IP?
12 Replies 12
If you have access to the ISP's router, you can try to create a NAT for port 500, but I've personally tested it and it didn't work.
So what I can say is that it probably won't work.
My suggestion is that you hire a dedicated link.
Schiller
Thank you @alemabrahao I also tried it and it didn't work.
So it's not possible. You need a public IP on the MX.
Schiller
Yes, It looks like I have no choice
Thank you for time @alemabrahao
thaack
If you are using IPsec, can you use the hostname in the Client VPN settings?
Schiller
Thank you @thaack I tried it and it didn't work.
thaack
Can you setup IP Passthrough on the ISP's router?
Schiller
No, I can't.
thaack
I'd reach out to your ISP to see what options you may have. Outside of @alemabrahao 1:1 NAT solution I can't think of anything else off the top of my head.
Schiller
I appreciate your help. I emailed the ISP about other options.
Brash
This should be doable if your port forward ports 500 and 4500 through your ISP's NAT
"If your MX is behind a NAT device (for example, an upstream router or ISP modem), the MX uplink If your MX is behind a NAT device (for example, an upstream router or ISP modem), the MX uplink IP might have a private IP in the 172.16.X.X or 192.168.X.X or 10.X.X.X subnet range. Ensure UDP traffic on ports 500 and 4500 is being forwarded to the private uplink IP address of the MX."
https://documentation.meraki.com/MX/Client_VPN/Guided_Client_VPN_Troubleshooting/Unable_to_Connect_t...
I tried this way a lot of the times, and it have never worked.
